Star Trek A Final Unity - Mouse and sound issue
Having problems with a specific game or application? Post your problems here!
Postby daspectrum » 2018-12-24 @ 02:24
im fairly new to the dos emulation work. I have run into an issue that if someone could five me some advice would be great. the issue i am having is that i configure the sound in the STTNG.ini and dosboxconf.ini file the same for the sound card SB16 port 220 irq 0x7 dma 0x5 hdma 0x5 which allows the sound to come out perfectly. This however stops the mouse, you cant move it you cant capture it nothing it is just as dead as a doorstop. you change the dma setting to 0x1 settings you get no sound and your mouse is moving (this is the only combination i have had to get the mouse moving) does anyone have some advice i have tried numerous combinations there has to be a conflict here but i cant pin point it.
daspectrum
Re: Star Trek A Final Unity - Mouse and sound issue
Postby Rwolf » 2019-1-25 @ 22:40
Are you using identical dma channels? Normally DOS used low dma 1-3 and high dma 5-7 for the SB-16 depending on what other hardware was in your computer.
(I have the game somewhere in storage, but I have not tried it in DOSbox, so I hope this is the problem. If not I can dig it out to try.)
Rwolf
Postby ash403638 » 2019-1-27 @ 11:16
Hello,
I'm not sure if I should make a new thread as this one is very recent and I'm having a similar issue with my mouse. The sound works fine but the mouse won't move at all, it's firmly stuck on the screen. I've tried using ctrl+f10 with no luck and I've tried adjusting the config file to disable autolock. I've searched on google for the past hour and have had no luck so far.
My sound settings are these:
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
Everything else is working fine.
ash403638
Postby Rwolf » 2019-1-27 @ 17:57
I just tried this game in DosBox, and for me it works fine, no mouse/sound problems (other than some minor skips when loading new dialogue, then background sounds stops temporarily, could probably be fixed by increasing cpu cycles.)
My sound settings are the same as 'ash403638'; using dosbox 0.74 with 'D-Fend Reloaded 1.44' front end.
I did let the game autodetect sound settings during installation, and it found my preset SB-16 settings, with all other emulated sound devices turned off. The game itself is v1.0
Using the mouse & subtitles on, I used the mouse for dialogue selection in the initial mission and the menu navigation, all working fine here. Running DosBox under XP64, which may not be what you have.
Rwolf
Postby red_avatar » 2019-2-08 @ 11:59
Final Unity has worked fine for many years but the only issue I always had, was with mouse movement being slow or inaccurate, even with mouse speed set to maximum. Someone gave me a patch for that years ago on this forum. It may be related to your issue.
Other than that, I have the same settings you have.
One thing I do that many people don't: LIMIT YOUR CYCLES. I think that most front ends set it to max or auto and that causes a LOT of problems for certain games. Games like Lemmings won't have sound and some outright crash or have other issues if you give them too many cycles. For Final Unity, 70.000 cycles should be plenty.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
User avatar
red_avatar
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 3 guests
