How to configure sound in Monkey Island 1&2?
Having problems with a specific game or application? Post your problems here!
Postby doaks80 » 2018-12-27 @ 23:42
No setup or install script (or config file) to select sound device...is there a way? Original non-CD VGA versions in DOSBOX currently.
k6-3+ 400 / s3 virge DX+voodoo1 / awe32(32mb)
via c3 866 / s3 savage4+voodoo2 sli / audigy1+awe64(8mb)
athlon xp 3200+ / voodoo5 5500 / diamond mx300
pentium4 3400 / geforce fx5950U / audigy2 ZS
core2duo E8500 / radeon HD5850 / x-fi titanium
doaks80
Re: How to configure sound in Monkey Island 1&2?
Postby lightmaster » 2018-12-27 @ 23:46
Gog or Steam version?
User avatar
lightmaster
Postby doaks80 » 2018-12-27 @ 23:51
lightmaster wrote:Gog or Steam version?
Floppy versions.
doaks80
Postby CrossBow777 » 2018-12-28 @ 00:05
The original floppy games basically defaulted to adlib sound or PC speaker if adlib couldn't be found. To force to something else like roland, required a patch file for the original monkey Island 1 but once in place, you would initiate roland sound by using the -r switch after the executable.
So..
monkey -r -v
I believe should load up monkey island 1 with VGA graphics (Assuming you have the VGA version) and roland sound for MT-32.
Monkey island 2 is similar if I've not mistaken?
User avatar
CrossBow777
Postby doaks80 » 2018-12-28 @ 00:34
CrossBow777 wrote:The original floppy games basically defaulted to adlib sound or PC speaker if adlib couldn't be found. To force to something else like roland, required a patch file for the original monkey Island 1 but once in place, you would initiate roland sound by using the -r switch after the executable.
So..
monkey -r -v
Thanks brother...just tried it out on my external CM-32L and it sounds great. Although the command in just "monkey r v" without the "-" :)
doaks80
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: knowledge [bot] and 1 guest
