First post, by asher
i have a p4 1.7ghz with 512 ram.
i have the latest cvs of dosbox, and i'm trying to run privateer.
with the latest cvs, privateer runs a lot more smoothly than before - but is still real choppy. all the threads i've searched people seem to be doing fine after they have the cvs build, but it's still pretty choppy for me. i try upping the cycles and it still has no effect.
I have it set on 7500 but the avg seems to be around 5000 actual cycles. so it usually says like 5000 = 7500 cycles
is my system not good enough to handle it? or is there some additional tweaking i can do?
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
uhm try overlay as output and set frameskip to 1
and set your display depth to 16 bit.
Water flows down the stream
