First post, by misa
Please, don't you have any idea how to launch the mentioned encyclopedia in DOSBox? It wants to know the driver of CD-ROM drive in CONFIG.SYS together with device name as well as MSCDEX with the identical device name otherwise it generates an error (can't find local CD-ROM drive). Maybe it is because of it combines the text of encyclopedia articles with sounds (produced by headphones inserted into the CD-ROM). The mentioned error was also in Windows 98 and XP. However, in Windows 98 was possible to use the bootable diskette and the encyclopedia worked… Now I am using Windows 10. Thanks in advance!
