First post, by dosdude82
Hi 😀
Whenever I play NBA Jam Tournament Edition under Dosbox 0.74 it flickers like crazy and I think the speed is off as well.
I have the real CD of it and run it as a .cue /.bin file.
What cpu type and cycles do I have to set the dosbox.conf file to?
Has anyone else experienced this same problem?
Thanks 😀
Reply 4 of 4, by Yesterplay80
Changing the machine setting doesn't work. The flickering occurs when DOSBox runs with more than 23500 cycles. It's a long known problem: NBA Jam TE and flickering
DOSBox-X seems to work with NAB JAM TE, though.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
