First post, by equinox2009
Hi. When I tried to run Oh No! More Lemmings under DOSBox v0.62, it asked for the disk to be inserted. Nothing happened when I pressed any key or click the mouse. I dont have the disk and tried to run it straight from the HDD.
Anybody has the solution to this?
Reply 2 of 6, by equinox2009
I had the files at "c:\lemmings\ohno\" . So, in dosbox prompt, I should type "mount a c:\lemmings\ohno" , right?
Then I typed "a:", then "vgalemmi".
That was what I did and it still asked for the disk.
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
hmm did you try the -t floppy as well
mount a c:\whater -t floppy ?
Do you know if this happened with 0.61 as well ?
Water flows down the stream
Reply 4 of 6, by Skydive
This worked for me, thanks. I am using 0.62. I also had this problem in 0.61 but I didn't know about the "-t floppy" option back then.
Check out the FreeCol project.
Reply 6 of 6, by bigfloppy
I am having the same problem. I am using a version off the net.
My original Oh no more lemmings game is an add-on and asks for the original version game Lemmings disk to be inserted into the floppy drive. This however is a 5.25" floppy.
Any idea how to get either Oh No working?
