First post, by Crysli
Hello,
in Wolf (from Sanctuary Woods) with DOSBox ECE there is no SFX sound when SB is selected in setup.
However it's working fine with DOSBox 0.74-2. Then I had tried with older ECE release and found out that the problems has begun in r4066.
In this SVN the sound is present but there is a costant background pulsating noise.
From r4174 there is no sound at all.
I think the problem isn't specific to the ECE version, from the DOSBox SVN changelog I see:
[r4066] src/hardware/sblaster.cpp: Allow an autoinit transfer to
go over into a single cycle transfer
Fixes Paddlers.
[r4174] src/hardware/sblaster.cpp: Make autoinit exit work and
prevent double single cycle transfers when quitting autoinit
