Their Finest hour install through Dosbox - disk space error
Having problems with a specific game or application? Post your problems here!
Postby Agathosdaimon » 2019-7-24 @ 06:22
hi!
I have tried this now with two different versions of "Their Finest Hour" - both a disk and a cdrom version: when i run the install, i get an error that the hard disk is full, when in actually fact i have like over 40gigs free on the drive and the c drive i use for Dosbox is just mount c c:\games - this is the only game so far where the install throws up this error
can someone help me please and tell me how i might be able to have the install recognise that i have enough space free - is it somethingi n the config i need to change or is there a command i can type in?
thank you
Agathosdaimon
Re: Their Finest hour install through Dosbox - disk space error
Postby root42 » 2019-7-24 @ 06:52
You can specify the amount of free space of a mounted directory with the -freesize parameter to the mount command:
https://www.dosbox.com/wiki/MOUNT
Soldering, retro game reviews and more on YouTube and Bonus videos
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, Jazz16, PC MIDI Card + SC55MkII + MT32, XT CF Lite, OSSC 1.6
User avatar
root42
Postby Agathosdaimon » 2019-7-24 @ 08:49
okay thanks - i tried that now with a few variations of size - 200, 500, 1024 - all the same error, i dont know what the games install's problem is -- i am assuming the freesize is measured in megs?
Agathosdaimon
Postby root42 » 2019-7-24 @ 09:05
I would guess so. A simple "dir" will tell you for sure. Can you post a video or pictures of the installation? Do you install from floppy images? Or did you copy the installation files to the c drive prior?
User avatar
root42
Postby jmarsh » 2019-7-24 @ 09:29
It's probably something else going wrong with copying files and the installer incorrectly assumes the problem is a lack of free space.
DOSBox's internal copy command doesn't handle wildcards very well so you might want to try installing under freedos or similar.
jmarsh
Postby Agathosdaimon » 2019-7-24 @ 09:54
i was loading a cdrom drive and going from the install on that - the cd i have is a "CD Power" from 1997 it contains Their FInest Hour with all the extra missions.
i have however found a solution - in that if i just copy the files over to a folder through windows copy paste and just run the game exe, then the game runs perfectly, so i guess i dont need to worry about the install error - but its a shame as i do enjoy the nostalgia of doing a dos install when i can :)
Agathosdaimon
Postby DosFreak » 2019-7-24 @ 11:20
I owned a 40meg HD in my 286 back in 1990 so may want to try smaller than 200mb.
User avatar
DosFreak
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 2 guests
