First post, by kekko
The game runs well, but if I press an arrow key too long (more than 1 sec) the game slows down until I release the key. this is a bit bothering in a flight simulator. It seems to be a kind of keyboard buffer overflow....
Apparently any dosbox version does it. I use dynamic core on an athlon xp and win 2000.
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
well dynamic core can sometimes cause slowdown if many irq are generated. You might want to try it again with the upcoming next version as that one has some different key repeat. Maybe that will benifit your cause.
Water flows down the stream
