First post, by braindead
I'm unable to play Doom with Gravis Ultrasound.
I tried to follow the steps and downloaded the drivers like shown in the description below:
https://www.google.com/amp/www.pc-freak.net/b … experience/amp/
After I did these settings on the DosBox configuration file and put the drivers into the right folder, I tried to enable Gravis Ultrasound in the setup configuration of Doom.
Unfortunetely I can't listen any Music.
I have no idea what exactly I need to do.
Reply 1 of 4, by braindead
I downloaded the files from here:
https://mega.nz/#!PUAwXJgK!Mw9M7YUqEWtZPhxAcA … 4rkIwEhAg0cGoWc
The I changed the dosbox config file like this and moved the drivers to the folder ULTRASND.
gus=true
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:ULTRASND
I does not work.
Reply 2 of 4, by Falcosoft
braindead wrote:
I downloaded the files from here: https://mega.nz/#!PUAwXJgK!Mw9M7YUqEWtZPhxAcA … 4rkIwEhAg0cGoWc […]
gus=true
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:ULTRASND
I does not work.
"ultradir=C:ULTRASND" dos not designate a valid path. This must be a typo in the article. This path should be corrected to "ultradir=C:\ULTRASND"
Also make sure that "C:\ULTRASND\MIDI" directory contains all the necessary *.PAT files (about ~196 pat files)
Website, Facebook, Youtube
Falcosoft Midi Player + Munt VSTi + BassMidi VSTi topic
Reply 4 of 4, by braindead
What driver package do you recomend?
I also used D-Fend Reliaded to designate the path
http://dfendreloaded.sourceforge.net/Download.html?lang=de
like in this video
https://www.youtube.com/watch?v=GXIcABOnvZo&app=desktop
I have no Idea how to run GUS propperly.
What file do I need and how to designate the path for the drivers directory.
