First post, by happyloaf
I just downloaded dosbox and I have gotten falcon to run under it. But how do I use a USB joystick? I also have a throttle wheel that is attached to the joystick. How can I emulate both of these in dosbox? Or anyother program. I'd prefer to emulate them as a thrustmaster pro.
Reply 1 of 3, by gulikoza
USB joystick is supposed to be working normally. But it will only show as a 2 axis, 2 button joystick. There was a patch some time ago to allow thrustmaster pro emulation and button mapping but it was not accepted.
Reply 2 of 3, by happyloaf
It doesn't even recognize the joystick! That's what I need to get dosbox to do. I can get it to work on VDMSound but the sound is all screwey. I can live with it reading it as a 2 button joystick fo rnow untill new versions come out. I just want to do some carrier landings!
