This is really a complex issue, so far i dont see the answer in those guides or in the readme
Can anyone give me a sample config file to get the sound to work? Im not looking to master dosbox, i have better things to do. If I have to do this on my own I can alter my config.sys to get the sound to work I was hoping there was a straightfoward solution though
"A config file can be generated by CONFIG.COM, which can be found on the
internal dosbox Z: drive when you start up dosbox. Look in the internal
programs section of the readme for usage of CONFIG.COM."
"CONFIG [-writeconf] [-writelang] localfile
Write the current configuration or language settings to file.
"localfile" is located on the local drive !!!
Example:
To create a configfile in your current directory:
config -writeconf dosbox.conf"
this is just chinese to me. Does the dosbox program itself have to be located in (i.e.) "dosprogs" folder when you mount it?
