First post, by nicka
'Murder makes strange deadfellows' is a rare game but can be found on a abandonware site.
It crashes everytime after few seconds
'Exit to error: PIC:Unhandled command 68'
Reply 3 of 17, by MiniMax
Rank Moderator
Moderator
Not sure if this will work, but try editing the file dosbox.conf (should be in the same directory as the dosbox.exe itself). Find the section named "sdl", and try changing the value of "output=" to one of "surface", "overlay", "opengl", or "openglnb".
_________________
Reply 5 of 17, by zorach
Hmm, what I'm getting here with 0.63 is two splash screens with grey background (and accompanying redbook audio), then scene with a castle, then about a second of music and out to the prompt with "aborted." Is that what you're seeing?
IRunning under the normal core it exits with "Exit to error: PIC:Unhandled command 48" (OCW3 reset special mask) which indeed does not appear to be implemented in pic.cpp.
However, as 4A is implemented (reset special mask and read ISR on next read), I simply copied it over (without changing the ISR/IRR bit), and this makes it work. Patch against current CVS attached.
    OCW3_48.diff
    680 Bytes
    169 downloads
    Implements PIC OCW3 48--reset special
Reply 6 of 17, by nicka
yep
How can I install this patch?
Reply 7 of 17, by zorach
Ah, well, there are three ways to do that...
-grab the latest CVS, apply patch, compile, install. Since you're asking the question, I doubt this is a good route for you
-Hope the DOSBox maintainers decide this is worth including and put it in the main source tree, then grab the latest CVS build (unsupported, may have sharp edges)
-Same as #2, except wait for the next official release
So for now, basically, wait 😀
Reply 12 of 17, by Jiri
It seems that recent changes broke something in this game. I have CVS from 29.4.2005 and graphics in the intro looks fine, but with current CVS the pictures are garbled. The messy graphics is probably only in the intro, everything looks fine later in the game (but I did not play it until the end). I attached two pictures - the game intro in current CVS and the same scene in CVS from 29.4.2005.
Reply 15 of 17, by Qbix
Rank DOSBox Author
DOSBox Author
I checked the cvs for changes in that period.
I would be happy if somebody could figure out which ones are responsible.
I removed all non-relevant code
    weirdcolour.diff
    7.24 KiB
    154 downloads
    weirdcolour strange fellow dates diff
Water flows down the stream
Reply 16 of 17, by HunterZ
Could this be related: RoA : Star Trail + Dosbox 0.62, still annoying graphics glitchs
eL_pusher reports problems in the latest CVS. I was able to replicate corrupted palette symptoms.
Reply 17 of 17, by Qbix
Rank DOSBox Author
DOSBox Author
that problem is older. although it might be related. (as it got worse I recall)
