First post, by genoism
Hey guys,
I'm running on winXP
with a ati 9800 pro
Asus mobo 64bit proc at 3200+
When i play FG, a lot of the text overlaps itself and it doesn't refresh when its supposed to. Meaning if it says x killed y units, then the next time it happens x killed y units will overlap the previous x killed y units. Everything else works just fine but it just needs to refresh this but doesnt. Any setting that could fix this?
