First post, by oldgamer85
Running dos Mortal Kombat Trilogy on stand-alone dosbox 0.74-3, while using no form of fps control (vsync or anything else), and monitoring its fps with RTSS, I noticed MKT runs at something that approaches 63fps, so it seems the game regulates itself to this fps.
But I'm wondering if that might be somehow wrong, as I have someone in another forum telling me that it is 70Hz instead. I tend to trust dosbox standalone more, but I'm trying to be sure of things before telling people they're wrong, plus I don't want to sound confrontational, just want to figure things out.
My ultimate objective is to run MKT on a crt tv set and give the tv a refresh rate that matches MKT as close as possible.
So, which one is the correct, 63 or 70 Hz?
I know several/many DOS games did run at 70Hz, but it seems 63 is the correct value for MKT (even though its a strange value) plus MKT is a 240p game (which weren't the ones running @70fps AFAIK).
Also, I've found a thread here on vogons where I first learned this fact and other good things about MKT so I could get it to run, here it is:
Mortal Kombat Trilogy hints and observations
