First post, by Harkonnen
Hi,
Congratulations for DOSBox, a great emulator ! It's really a good job !
I use DOSBox since v0.61, and on this version I was able to run 2nd Reality demo without problem.
But since 0.62, when I start it, i have the following message after sound mode selection :
"Fatal signal : segmentation fault (SDL parachute deployed)"
This message appears in v 0.63 too.
Any idea to solve this ?
Thanks.
Reply 3 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
just tried it with 0.63
works fine
you might want to check your 2nd reality download as it runs fine with default setup of dosbox
Water flows down the stream
Reply 8 of 8, by MiniMax
Rank Moderator
Moderator
I don't understand either 😀 It seems to run perfectly for me.
Here is what I did:
  1. Read the instructions listed on PAiN.
  2. Downloaded 2nd_real.zip .
  3. Downloaded 2ndpatch.zip.
  4. Unpacked the demo (2nd_real.zip) into a demo directory.
  5. Unpacked the patch (2ndpatch.zip) and placed the "fixer" ((2ndfix.exe) in the demo directory.
  6. Created a DOSBox configuration (dosbox.conf) according to the instructions and put it in the demo directory:
    [dosbox]
    memsize=32
    [cpu]
    cycles=5000
    [sblaster]
    type=none
    [dos]
    xms=false
  7. Started DOSBox:
    dosbox -conf demo\dosbox.conf demo\2ndfix.exe
  8. Hit ENTER to start the demo.
  9. Leaned back and enjoyed the show!
_________________
