First post, by red_avatar
After years and years of looking, I finally got my hands on this underrated FPS but now that I got it, DOSBOX won't run it 🙁. The games catalogue shows that it should work. This is the full and original CD version. I install, pick the lowest options possible and then try to run the game but it crashes dosbox completely.
Does anyone here know how to get it running?
Reply 1 of 3, by red_avatar
Update: it works fine now but:
SB16 mode doesn't work
you need to change the label to that of the CD
you need to use full install
and only VGA
When I did all that it worked fine with sound and all at a decent speed too.
