First post, by elf316
Hello all and thank you in advance to anyone who posts replies to this.
#1 I have Champions of Krynn loaded onto my hdd, I run dosbox and mount the drive and the floppy. I try to create a character and it keps telling to insert a disk to save it to. I read somewhere that I should just modify the CFG file of Krynn, but it's blank.
#2 I also have Menzoberranzan and it loads and installs correctly, but after I run it and complete the sound config, I run the Menzo executable and it comes back telling me that's it's "Unable to open resource file"
and lastly: I loaded up on Pool of Radiance (from Home of the Underdogs) and everything's fine until it tells me to check the Code Wheel. Nothing I write in is correct. I've checked numerous sites and double-checked the code words, still nothing is good.
Thank you !!!
