First post, by Ilya
I'm writing a modern version of a program were written in Clipper 5 and I need to view it using debugger. One moment DOS applications stopped working under Windows 2003 and I'm trying to use DosBox. To run this debugger it must be wrote lines
SET CLIPPER=F:225
in autoexec.bat that I've wrote and
EMMExclude=C000-CFFF
PerVMFiles=225
in system.ini. The second one I can't understand where to write. The program doesn't run, openning files fails. I think the reason is absence of these lines. Also I need this program to be normally readable to install cyrillic font and I've not found how to do it in DOSBox. The message about failing opening file I can't read too because Russian letters are not shown properly.
