X-Men Children of the Atom
First post, by teleguy
Every time I run X Men from URL REMOVED, DO NOT POST LINKS TO ABANDONWARE using Dosbox 0.61 I get the message "Cannot find the X-Men Cd in the CDROM drive" .
I already tried burning the extracted files on a CD Image and mounting it with Deamon Tools but that didn't help.
Reply 6 of 13, by teleguy
I recently tried the game again and got it to run fairly well and with sound.
( I'll attach a profile for D-Fend/Dosbox 63 in case anybody wants to play the game but has problems with it.)
However there's still something wrong with the display . All the colors seem to be inverted . Does anybody know what's causing this (perhaps the modified VESA driver ?) and how this can be fixed ?
Any help is greatly appreciated.
Edit: I also have another problem. I downloaded Dos32a.exe , copied it into the game folder only and renamed it to Dos4gw.exe . Since then every time I want to delete or rename either Dos32a.exe or any Dos4gw file in any folder on my harddrives I get a message that the file is in use.
    Xmen.zip
    863 Bytes
    682 downloads
Reply 11 of 13, by teleguy
vyr wrote:
teleguy, could you or someone else explain in more detail how you got past the CD problem? I've extracted all files to C:\XMEN and tried to run the game in DOSBox 0.70 but got the same error as in your first post.
Here's an updated Profile (created with D-Fend v2 beta) that should work with Dosbox 0.70 and hopefully fix your problem. I also noticed the modified Vesa driver isn't needed anymore.
    XMEN.zip
    747 Bytes
    648 downloads
Reply 12 of 13, by lucio
I resolved this problem and run the game only mounting the CD drive (without any CD inside) with this command:
mount d D:\ -t cdrom
There's several commands to mount the CD drive. See also in DosBox:
intro cdrom
After this, I run the game with:
xmen.bat
Thanks.
