First post, by ReignerDeustcher
I want to play The Journeyman project 2 (3 cds) in dosbox with windows 3.11 and even with the images mounted correctly when i run the game it ask for change disk
what's wrong here?
mount C .\C
imgmount D "CD:\BITSP1.iso" -t iso
imgmount D "CD:\BITSP2.iso" -t iso
imgmount D "CD:\BITSP3.iso" -t iso
PATH C:\WINDOWS;
SET TEMP=C:\WINDOWS\TEMP
Win /N C:\BITMPC\BITMPC.EXE
exit
Reply 1 of 6, by jmarsh
What type of system are you running DOSBox on? I ask because "CD:\" doesn't look like a valid path for most OSes.
Anyway, if you want to mount multiple images and switch between them you need to put them all in one command:
imgmount D "CD:\BITSP1.iso" "CD:\BITSP2.iso" "CD:\BITSP3.iso" -t iso
Then use ctrl-F4 to cycle between them when it asks you to change disks.
Reply 2 of 6, by ReignerDeustcher
jmarsh wrote on 2020-08-17, 00:46:
What type of system are you running DOSBox on? I ask because "CD:\" doesn't look like a valid path for most OSes. […]
i'm on win 10, CD is the folder where i have the isos
tried the line that you gave me but now dosbox doesn't mount them, says the images must be on a host or local drive
Reply 3 of 6, by Jorpho
ReignerDeustcher wrote on 2020-08-17, 02:01:
Then why are you typing "CD:\" ? The colon character is only used for drive letters.
It might work if you use
imgmount D "CD\BITSP1.iso" "CD\BITSP2.iso" "CD\BITSP3.iso" -t iso
Reply 4 of 6, by ReignerDeustcher
Jorpho wrote on 2020-08-17, 03:13:
Then why are you typing "CD:\" ? The colon character is only used for drive letters. […]
it works now, thanks!
Reply 5 of 6, by _Rob
Not sure if this is one of them, but some games support multiple CD-ROM drives, in which case you do not need to do any CD swaps.
e.g.
imgmount D "CD\BITSP1.iso" -t iso
imgmount E "CD\BITSP2.iso" -t iso
imgmount F "CD\BITSP3.iso" -t iso
Reply 6 of 6, by ReignerDeustcher
_Rob wrote on 2020-08-17, 13:46:
Not sure if this is one of them, but some games support multiple CD-ROM drives, in which case you do not need to do any CD swaps […]
e.g.
tried it but seems that this game doesn't support that, thanks anyway
