First post, by Monzor
Hi,
I recently bought (yes BOUGHT 😀 ) bedlam. I tried to install it with dosbox 0.63 with opengl and alsa compiled in. First i get in a dos setup menu where i can select sound and test it.
Several soundcards such as SB16 seem to work when testing it. The game can then also be started an actually be played. That is: you can move around.
Ingame the sound doesn't work anymore unfortunatly. Also the game seems to have a really low fps, even with some .dosbox "tweaks".
Anyway, i think the game should be rated "runable on the
runable - playable - supported
bar associated with Bedlam.
Also i'd like to figure out what's causing the nosound and slow performance problems so perhaps the game can be rated playable or even supported !
