First post, by Akuma
When using the overlay function, captures are still written the original mount.
eg:
mount c /somewhere/original <--- captures are written here
mount c /somewhere/overlay -t overlay <--- instead of here
Is this intentional ? because personally I'd expect them to be in the overlay 😁
EDIT: Its written to the folder where dosbox.conf resides isn't it ?
Reply 1 of 4, by zirkoni
This?
DOSBox.conf wrote:
[dosbox] # language: Select another language file. # machine: The type of machine DOSBox tries to emulate. # Possible […]
[dosbox]
# Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
# captures: Directory where things like wave, midi, screenshot get captured.
# memsize: Amount of memory DOSBox has in megabytes.
https://www.youtube.com/user/zirkoni88
Reply 3 of 4, by Akuma
zirkoni wrote on 2020-10-14, 12:20:
This?
[dosbox]
Yup, that one
jmarsh wrote on 2020-10-14, 12:27:
Yeah, captures has its own path on the host that has nothing to do with any mounted drives.
By default it's the "capture" subdirectory of the folder where the current config file is located.
Can I use an absolute path ? It does not say in the config.
