Menzoberranzan Refusing to load
Reply 20 of 30, by Tarkania
It sounds like you had the same problem I had. Hopefully, this is your solution as well - 6 months later!
The following is a revised install/execute method based on DosFreak's very, very excellent post.
I have the Gamefest Forgotten Realms' compilation CD:
1. Install Menzoberranzan using CD's Win installer, installed into C:\Oldies\menzo
2. Open CD itself and copy over all RESXX files into install directory. For me these were: RES3, RES6, RES9 and RES10. Replace if prompted.
3. Copy CINE (cinematic) folder into install directory.
4. Copy CGEN (char. gen.) folder into install directory. [THIS WAS MY SOLN]
5. Edit INFO.DAT within install directory and change drive letter to C:
6. Open DOSBOX (I use D-Fend)
mount C: C:\Oldies\menzo
7. Set up sound thru DosBox using SOUND.BAT (Roland and SB16)
8. Execute program with MENZO.bat
NOTE: for #s 2-4 these items were found in D:\ itself not in its D:\menzo folder.
It should work with no problems!
Specific tweaking suggestions for smoother play are welcome.
Reply 23 of 30, by Taeliac
Okay, so I have wracked my brains, but I think I've hit an odd stumbling block that no amount of Googling has seemed to help with.
I, too, am getting the "can't open resource file" error message.
I realize I should try editing the INFO.DAT file, but I'm on OSX. Is that a problem? I can't seem to edit it in DOSBox, and I don't have any software that is letting me edit the .DAT file 😅
Reply 24 of 30, by MiniMax
Rank Moderator
Moderator
Sure you have. Have you tried TextEdit?
_________________
Reply 25 of 30, by Taeliac
Actually, that was indeed the first thing I tried. I don't know if this is some coding that I just do not understand, but I don't see how to change the drive letter... I have also tried this in NeoOffice, Pages, and DreamWeaver, to get the same result each time.
Here is what I am getting, when I use TextEdit:
0000000001111(the symbol for "greather than and equal to", > with a line under it):
It shows the little box no matter how I copy/paste it, and nothing after that. Here it is, for direct copy/paste:
0000000001111
Reply 26 of 30, by Sheriff Hobbes
The game loads fine and the sound is Ok too. However, when I start a new game, it says "not enough memory to continue" and quits to the main menu. I've tried several memory options, different DOSBox versions and the DOS32a extender. Any ideas?
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
