First post, by Jarek Blunt
I just found this application (using the newest one 0.63) and I'm trying it for the first time to run The Bard's Tale. I downloaded the game for MSDOS and I tried setting it up but when I use the following commands it doesn't work.
I type
cd Bard's Tale (that's how the directory is called) and it says unable to change to Bard's Tale
Thank
JB
