First post, by user222
If you run the newest version of "DOS Navigator" in DOSBox, DOSBox exits. Download the application from
[http://dnosp.ru/lite/dnosp.htm].
Reply 2 of 9, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
eL_PuSHeR wrote:
Doesn't DN run already under native NTVDM? Why do you want to use it under DOSBox? More comfortable managing files?
I guess this is his reason. I remember how happy I was when DOSBOX got to the state where Volkov Commander worked. 😀 I run it every time in DOSBOX.
There is a legitimate case for using DOS file managers in DOSBOX (so I would not dismiss this problem)
Mirek
Reply 3 of 9, by mirekluza
DOSBox Moderator
Exit to error: Unhandled Dos 21 call 64
DOS 3.2+ internal - SET DEVICE DRIVER LOOKAHEAD FLAG AH = 64h AL = flag 00h (default) call device driver function 5 (non-dest re […]
AH = 64h
AL = flag
00h (default) call device driver function 5 (non-dest read)
before INT 21/AH=01h,08h,0Ah
nonzero don't call driver function 5
Return:
Nothing (MS-DOS)
CF set, AX=error code??? (DR DOS 5.0, which does not support this call)
Mirek
Reply 5 of 9, by user222
mirekluza wrote:
Easy to fix in DOSBOX source (just removing that exit for int 21/64 in DOS.CPP). I will put a message on beta board.
Mirek
Why isn't this patch applied to the official CVS repository, and it's not compiled into the binaries on CVS Compile?
Reply 6 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
as it didn't make it to the beta board.
thank you for your friendly reminder.
Why isn't this ......
Water flows down the stream
Reply 7 of 9, by mirekluza
DOSBox Moderator
It did make it to beta board (Broken programs): Topic 7782
Just a warning: the above mentioned link is accessible only for beta testers, so please do not complain that it does not work.
Mirek
Reply 8 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
hmm you are right.
I didn't remember it though 🙁
Glad to see you Mirek!
Anyway. Still no excuse for the why part of the question.
Reply 9 of 9, by Dominus
DOSBox Moderator
I also want to be a beta tester. I can dance naked if it helps 😀
couldn't resist, just kidding (about the beta testing, as I'm effectively doing it anyway 😀)
