First post, by user222
If you start the DOS GUI "Seal" in DOSBox, DOSBox exits.
before DOSBox exits, it displays this error message:
    13.4 KiB
Reply 2 of 6, by user222
eL_PuSHeR wrote:
Hmm, that program seem to be looking for a specific model of VGA card. Is there any way to instruct it using VESA?
Another reason that it doesn't run is because it needs DPMI, besides the graphic card.
Reply 4 of 6, by user222
Disregard the last two replies. The error was probably cause by an unhandled DOS call.
    25.14 KiB
Reply 5 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
unlikely.
it's a protected mode check
http://www.delorie.com/djgpp/doc/rbinter/id/38/46.html
it should fails else the game assumes there is allready a dpmi handler installed.
fails and unhandled are the same for multiplex functions
Water flows down the stream
Reply 6 of 6, by user222
The file "SEAL.EXE" has the "CWSDPMI" embedded in it. After I started "CWSDPMI" before I started "SEAL", I got a different error message.
