First post, by DosFreak
- l33t++
DosBox CVS 1/17/2005
Windows 1.0
Drops back to DOS during install, probably corrupted copy.
Windows 1.01
The following happens during installation:
Get write 0 to rom at ff904
write 0 to rom at ff900
write 1 to rom at ff903
Freezes dosbox.
Windows 1.02
Setup halts during installation, no indication of falied install, installation just halts while copying files.
Output in console:
14697: FILES:file open command 0 file CITOH.DRV
15208: FILES:file open command 0 file COURA.FON
15364: FILES:file open command 0 file COURB.FON
15520: FILES:file open command 0 file COURC.FON
Windows 1.03
setup just repeats screen.
Windows 1.04
Windows 2.03
Install finishes.
When run win.com, logo flashes for split-second then drops back to DOS.
Get this in console:
87209: FCB:DOS:29:FCB Parse Filename, result:al=0
87210: EXEC:Execute C:\WINDOWS\21386\WIN200.BIN 0
87210: FILES:file open command 0 file C:\WINDOWS\21386\WIN200.BIN
87210: EXEC:Illegal header
87236: INT10:Set Video Mode 3
87236: VGA:Blinking 8
87243: VGA:H total 100, V Total 449
87243: VGA:H D End 80, V D End 400
87243: VGA:Width 640, Height 400, fps 70.309021
87243: VGA:normal width, normal height aspect 1.000000
Windows 2.1 (286)
Install finishes.
90460: FCB:DOS:29:FCB Parse Filename, result:al=0
90461: EXEC:Execute C:\WINDOWS\21286\WIN200.BIN 0
90461: FILES:file open command 0 file C:\WINDOWS\21286\WIN200.BIN
90461: EXEC:Illegal header
90487: INT10:Set Video Mode 3
90487: VGA:Blinking 8
90494: VGA:H total 100, V Total 449
90494: VGA:H D End 80, V D End 400
90494: VGA:Width 640, Height 400, fps 70.309021
90494: VGA:normal width, normal height aspect 1.000000
Windows 2.1 (386)
When run win86.com, logo flashes for split-second then drops back to DOS.
Windows 3.00
Works!
Windows 3.1
Setup locks up when it reached the screen where you enter Name, Computer Name, and workgroup.
Error on console:
a
3792860: KEYBOARD:Buffer full, dropping code
Windows 3.1 for Workgroups
Dynamic Core:
Error on console:
Windows 3.11 for Workgroups
Locks up where you enter name, company, product number:
Console:
1654131: KEYBOARD:Buffer full, dropping code
Full Core:
Keyboard works during install but mouse doesn't.
The following sums it up:
Windows 1.0 - Might be corrupt copy.
Windows 1.01 - Dynamic: Freezes dosbox during install. Full: Same
Windows 1.02 - Installation halts while copying files.
Windows 1.03 - Installation screens repeat, might be corrupt copy.
Windows 1.04 - Installation screens repeat, might be corrupt copy.
Windows 2.03 - Install finishes, Windows will not start.
Windows 2.1 (286) - Dynamic: Install finishes, Windows will not start. Full: Same
Windows 2.1 (386) - Dynamic: Install finishes, Windows will not start. Full: Same
Windows 3.00 - Works
Windows 3.1 - Dyamic: Setup freezes on Name, computer name, workgroup screen.
Full : keyboard works.
Windows 3.1 for Workgroups - Dynamic: Setup freezes on name screen. Full: keyboard works
Windows 3.11 for workgroups - Dynamic: Setup freezes on name screen. Full: Keyboard works but mouse doesn't.
Windows 1x - Not sure what's going on there. I would say corrupted copies but all but 1 of my Windows 1x copies came from images. The way I installed them in Dosbox is I extracted the images to one directory and then installed from there by mounting the directory as an A drive. I would like to install straight from the images but I am unsure how to do so under DosBox.
Windows 2x - Weird. Installation finishes but when I execute windows the logo flashes and then backt to DOS. The only thing I see in the output is an illegal header error after win.com executes win200.bin
Windows 3.x - It looks like keyboard doesn't work in dyanmic core sometimes and mouse doesn't work at all. when you execute FULL core the keyboard works and mouse still doesn't work.
