First post, by user222
Loadlin doesn't work. It needs VCPI.
    25.98 KiB
Reply 1 of 4, by laxdragon
Wow, why would you even want to run Linux under DOSbox?
If you want to run Linux under Windows, take a look at:
http://www.colinux.org/
Or use Bochs or VMware.
Reply 2 of 4, by avatar_58
Thats actually kind of funny though you have to admit! 😮 Try disabling XMS and EMS to see if it helps it along. Whether or not it will load all the way is another story. If it does, let us know! It would be funny...I mean why not? We already are at win3.11, why not nix?
Hey maybe once in linux you run the linux dosbox! 😳 Ok, I'll stop my crazy thoughts now..
ps- Theres also another problem...running linux in dos? Linux must boot on its own and not under another layer.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
yeah ems and xms must both be false.
then there is enough free memory (extended)
Water flows down the stream
