First post, by Mugworth22
Hi
I am trying to install and run UD\Genesia, However when i start the installer and choose where to install the game to it says "This is not a valid Hard Disc, please select a different destiination to install to."
I have mounted a folder where i have all my dos games inside as C:
and i have mounted my real cd drive as D: as type cd rom
with the C: drive i tried:
setting the -size property
setting the -t property
setting the -fs fat property
but the installer wont have it.
The game came with a program called "snap.exe" which detects all the hardware on your pc.
it found A: as type FDD and D: as type CDROM, but C: is unknown as is the default Z: drive.
I have tried to make an HDD image using bximage.exe as suggested in one of the dosbox guides. however i got as far as using freedos's fdisk to create a partion, but the format command would not work, and said it could only do floppys. I havent tried booting msdos 6 yet though.
Is there a program which can create a blank image and format it all in one?
so that it is ready to use straight away?
Also has anyone else tried to install the game?
