First post, by WGamradt
Hello,
I have an issue with running an DOS application via DOSbox after migrating over to a new server environment. The previous environment was running on Server 2012 systems and we migrated to Server 2019.
In the old setup DOSbox was working well with this application. The only change to the workstation environment was joining it to the new server domain. DOSbox was configured and working on this machine against the old environment without issue. Since moving to the new servers I am seeing the following:
1. One of the mount commands is not working. We are getting a file does not exist message. This does not make sense to me b/c of the following
Drive map 1 (Fails): Mount X \\server\share
Drive map 2 (Works): Mount Y \\server\share\app
Drive map 2 is a subfolder of drive map 1. If I can reach all the way down into the application, why can I not map one level above?
Drive mappings use different letters, I am not attempting to map both paths to the same drive letter. Both paths are required for proper function.
2. I am also seeing is that if I attempt to do a directory listing on the successful drive mapping, it takes an extremely long time to complete. You issue the 'dir' command and wait about 3 minutes for output. During this time all you see is a blinking cursor.
When I perform a 'dir' listing of a local path it is instant.
Due to several factors beyond my control, I am not able to compare the previous environment with the new to look for differences.
Thanks in advance for any suggestions.
