First post, by marcfero
This old and fantastic game does not work with DosBox, what a pity!
Do you have a solution to play this game with windows xp?
Thanks
Thanks
wrote:This old and fantastic game does not work with DosBox, what a pity!
Thanks
It does not work because there is an unhandled interrupt.
"CPU: Unhandled Interrupt Called 0"
I editted both posts.
DIRECT LINKING TO ABANDONWARE IS NOT ALLOWED. Thank you.
BTW: It works fine under Windows XP NTVDM native emulation.
CTRL-Q = Exit to DOS.
Thanks for your answer.
It doesn't work with NTVDM (COMMAND.COM) and the settings by default.
My OS is Win XP pro SP1.
Thanks for your help.
BTW stands for ?
I have Windows XP SP2.
BTW = By the way (abbreviated).
