First post, by rev79
First of all, I want to give a shout out to the developers of DOSBox. I've been trying to get these games going for ages now, trying every tweak and twitch known to be used- eventually corrupting my hard drive awhile back in the process. Then, I discovered your program, which is flat out amazing. There's no looking back now, I won't be using any other method. Thank you! 😁
Now to a few questions: I searched around the forum and couldn't find anything, so here it is: I have the Roberta Williams Anthology and have managed to get KQ6 going flawlessly. KQ5 looks great too and the music as well, but the speech isn't there. the faces pop up, and the mouths move, but no voice.
In addition, I also have the Police Quest Collection, and am having a bit of trouble with PQ4. Right now, its running a bit slow(even after adjusting the frame rate and cycles), no speech for this one either(it just pops and hisses a bit when its supposed to be speaking)...and the times I tried these two games I had to run them directly from the CD w/out installation because I couldn't find the Batch file. Basically, how do I get these games installed like I did KQ6? Running the install produces the screen containing options about which games to install in the series, but no matter what letter I press, it always says installing KQ1..then freezes up at that point.
Any help is appreciated. Again, thanks for the fabulous program.
