First post, by Andygee
Hello
My Problem is that i want to run Wing Commander Armada in my Network over ipx.
But when i want to activate ipx in the dosbox.conf armada says :
" Network Driver detected ! Cannot switch to protected Mode safely "
What is the problem about that ?
I use Windows XP and Dosbox 0.63
Is this a problem with armada or with Dosbox ?
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
it only happens if you have ipx is true.
somehow they don't like our ipx driver or so
Water flows down the stream
Reply 4 of 4, by Andygee
Yes it only happens if ipx=true
But could it be that the problem is that dosbox can´t run ipx and the protected mode at the same time ?
Because the message could be send froom dosbox too i am not sure about that !
I have talked to other users which had the same problem !
Has someone ever played Armada or Proving Grounds in Network mode ?
Is the Modem Mode playable too ? I havent tried this because i dont know how to configure the modem options ?
Thanks for your answeres
