First post, by John Hughes
Could someone provide the code, and if possible explanation, for how to load a game from the same folder that DosBox is in?
In this scenario, on my desktop is the DosBox folder. In this folder is the folder with the game in it. Let's call it 'GameFolder' for the example... now what would I type in order to open/load this game?
😀 Many thanks chaps!
John
Reply 1 of 9, by eL_PuSHeR
Feeling too lazy to read the readme, mate? 😁
mount c "c:\gamefolder"
mount d d:\ -t cdrom -label <youshouldhavereadthereadme>
d:
install.exe
c:
cd "gamefolder"
cd "folder_created_by_game_installation"
play.exe
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 9, by kode54
Obviously, the source paths will not be DOS style on a Mac, or Linux. You will probably want to form those as absolute paths, such as /home/user/GameFolder, depending on where GameFolder is located.
Reply 4 of 9, by John Hughes
I say
mount c:John/Desktop/DOSBox/1ac Folder
Which is the folder the game is in.
How would I run the "install.exe" file which is in this folder? I have tried
loadhigh:INSTALL.EXE
and other formats, help much appreciated fellows! 😀
Reply 5 of 9, by kode54
The format to mount is:
mount <drive letter> <path on host filesystem>
I presume that host path needs to be the full unix path even on Mac, but I may be wrong. Are there any front-ends for OS X? (Assuming you are using OS X...)
Reply 6 of 9, by MiniMax
Rank Moderator
Moderator
and NOT
mount <drive letter> <COLON> <path on host filesystem>
_________________
Reply 8 of 9, by John Hughes
Thanks, now how would I load Install.exe from that folder?
[/quote]
Reply 9 of 9, by MiniMax
Rank Moderator
Moderator
Explained here:
Re: I'm sorry this must be very basic - how does one load a game on a Mac
_________________
