Blood
First post, by kevingpo
Has anyone run Blood under DOSBox fast? Is DOSBox powerful enough to run a game like Blood?
Reply 1 of 9, by DosFreak
Depends on what you consider fast.
Athlon XP 2800+
Runs at 20+ fps in 320X200, dynamic core, frameskip=0, no sound.
Considering that on the host you can get around 200+ fps in 1600x1200, then yeah I wouldn't consider DosBox fast. 😉
You could up the frameskip a bit and perhaps get a bit higher resolution but your better off running under Windows XP, or using IceCold's WinBlood port (Still beta).
Make your games work offline
Reply 2 of 9, by kevingpo
When I ran it under DOSBox, Blood was so so slow. It started playing the demo of Blood (a recorded demo). I can hear it, but couldn't see it. Am wondering whether I need to tweak DOSBox, such as whether you can specify the CPU to emulate, etc.
Reply 3 of 9, by DosFreak
Make sure your dosbox.conf has core=dynamic and make sure Blood is set to 320x200 in blood.cfg.
Reply 6 of 9, by Cody Richeson
DosFreak wrote:
Depends on what you consider fast. […]
Athlon XP 2800+
How do you run it in the host? I tried but it didn't work at all.
Reply 9 of 9, by DosFreak
I tried looking for it last week but the forum/site disappeared. Odd because it looked like work was progressing on it...they probably just moved but now even a simple google search can't find any valid links.
