First post, by sombrio
Hi, can i play shadow of comet with dosbox 0.63 under windows xp?
Thanks 😊
Reply 1 of 2, by Telemaster
Simply. Just mount your CD/ISO at basic mounting level. Then run install.exe and that's it. Music, voices, sound effects - everything is running perfectly. Shadow of the comet doesn't demand high CPU cycles.
Ok, this is ideal situation. If you are trying to run some rip, there might be problems. I don't know, I have not tried it, since I possess full CD version.
