First post, by willem169
Hi, I've tried to find people who have the same problem as I do, but didn't find them. I've also tried to find solutions for my problem within this forum with no results. This is my problem: As I start Pinball Fantasies under DosBox on my 17" Powerbook, everything works great with the right ajustments, everything except the RIGHT flipper.
In other pinball games the exact same problem.
I don't know where to search for the cause of this problem.
The problem occures with the laptop keyboard itself AND with my Bluetooth keyboard, so I figured out that it's not the keyboard, but maybe the settings within the OS. I have no clue where to search. Does anybody have a tip for me? Thanks in advance!
PS.
Keep up the good work @ DosBox!
Reply 1 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Apparently something is interfering with the key the pinball games use for the right flipper and the key you press (or is that always a different key?).
Maybe you can use the keymapper to assigne another key to this game. Load the Dosbox Readme and look for Keymapper part.
Reply 4 of 4, by 3803
I've used to play Pinball Fantasies back then and I'm pretty sure I used left and right shift keys like in some other Pinball games.
I've played this game in Dosbox on a x86 machine about a year ago and it worked fine, except for a bit of flickering...which might have been solved by now. The flickering was the reason why I've played it only once in Dosbox.
