First post, by ZombieEater
I have W2Deluxe working fine under 0.62, sound, mouse, GFX, everything - COOL!!! 😁
But: Whenever I try to start a Random game, right after creation of the scenario (the progress bar hits 100%) I end up on the main menu, with the "Begin" button grayed out. Every time.
The random scenario is created, I can find it in my dir tree, and if I swap it out with one of the standard scenarios, I can even run it (so the random stuff is not corrupted or anything). But the renaming is tedious, so I'm wondering if anyone has it working, where you create a Random Scenario and it starts right away? 😖
Abit A8V
AMD64 3800
1GBRAM
Geforce gt 6800
on-board
WinXp Pro
Reply 2 of 4, by ZombieEater
Yea, I just saw that on the DB homepage. I grabbed the latest "stable" version from CVS I think.
I'll try 0.63.
Is there some obvious way (e.g. documented in readme) to enable some debug output? (No I haven't looked yet myself 😉 )Maybe I'm lucky and I see something, maybe W2DL is trying to access some path and fails.
Reply 3 of 4, by ZombieEater
Ok, I actually have 0.63 running. Still no go. 🙁
I'm running D-Fend, but I just checked and I have the same issue (no RMG games) with or without the GUI.
I checked the readme now and there doesn't seem to be an obvious way to turn on any debug output. I hope I won't have to recompile for debug!! 😳
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
well the debug version you can find the development forum. it's a sticky topic.
Water flows down the stream
