First post, by THE_WUQKED
Wondering why no-one has posted this here yet...
Anyway:
HCl did it again! He created a DosBox-patch for WC Armada and WC Armada Proving Grounds, which fixes the Joystick bug + allows you to play Armada Proving Grounds in Multiplayer online (via IPX):
For more Details and a download link, just check www.wcnews.com :
http://www.wcnews.com/news/showupdate.php?id=6279
http://www.wcnews.com/news/shownews.php?id=2030
So for me it's only WC3 making little trouble now. 😁
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
well those joya.dat files I can create as well. (as the detection sometimes works in the cvs version).
I'm not sure if that aramadb is the armada executable or the dosbox executable.
if it's a patched aramada executable then it's logical we don't know about it.
if it's a patched dosbox executable then he should include his changes in the source in the archive.
Water flows down the stream
Reply 2 of 2, by THE_WUQKED
It's a patch for Armada, not a modified dosbox-version. - But cause it's a patch that fixes DosBox related probs only, I thought I should post it here.
And I was wondering, why no-one mentioned it yet, cause I knew several threads about the Dosbox-Armada-Joystick prob being posted here... - Would have guessed others posted about it before (since it's some days old already), that's all.
