First post, by Musashi
Hi from Germany!
My problem is, that I can`t run Nobunaga`s Ambition II with DOSBox 0.63.
Is anybody out there who knows how to run or who has some experience with this great game ?
I just see the Intro and if want to skip it with "enter" then this appears:
"read open err A:KAODATA.DAT"
What can I do?
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
It is looking for the file KAODATA.DAT on drive A (a diskette).
Please read the ReadMe and/or the Wiki to learn how to create/make available a diskette in DOSBox.
_________________
Reply 2 of 5, by Musashi
thanks for your reply.
i did, for sure.
so i wrote in dosbox.exe:
mount C C:/oldgames (that`s where dosbox and my oldgames are)
mount A C:/oldgames/nobu2/a (it`s the folder for disk a)
mount B C:/oldgames/nobu2/b (it`s the folder for disk b)
A:/keyb gr (german keyboard)
A:
koei (necessary for starting the game)
Do you see any misstakes?
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
mount A C:/oldgames/nobu2/a -t floppy
mount B C:/oldgames/nobu2/b -t floppy
_________________
Reply 5 of 5, by MiniMax
Rank Moderator
Moderator
Hmm.. Instead of start the game directly (with "koei"), check if there is an extra program pn A: for configuring sound. It may be called sound.bat, sound.com, setup, or something.
If you find it, make sure that when it ask you for stuff like IO-address, DMA-address, IRQ-number, etc, etc, that you reply with the same values that is listed in the dosbox.conf file in your DOSBox program directory.
_________________
