First post, by Joeyxp2
I don't understand it. Everytime I try to run Terranova: Strike Force Centauri from Dos-box it says missing movies and I have them right in the folder. I also tried editing the configuration file to point it into the correct direction but it still won't work.
Reply 1 of 3, by eL_PuSHeR
Have you tried running the game natively and WITHOUT SOUND (if possible) under Windows to see if it runs at all?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 3, by Joeyxp2
I already did and it also said: ERROR: Missing movies
I can't even get setup running without gibberish if not running with Dosbox. It says Filed -2 for enginst.res <0>
when I'm trying to run setup. The Terranova game just exits by flashing right after I open it in Native Windows.
Reply 3 of 3, by Joeyxp2
Please, I really do not know what to do to get this game to work. I really want to play it. Has anyone got the same problem as me when they are trying to TerraNova? If so, how did you fix it?
