First post, by rolloLG
- Member
Strange issue with Lands of Lore: Throne of Chaos (V E1.23 in the bottom-right of main menu)... when I launch the game my audio settings go from:
Channel Main Main(dB)
MASTER 100:100 +0.00:+0.00
DISNEY 100:100 +0.00:+0.00
SPKR 10:10 -20.00:-20.00
GUS 100:100 +0.00:+0.00
SB 100:100 -20.00:-20.00
FM 100:100 -12.00:-12.00
to
SB 10:10 -20.00:-20.00
FM 25:25 -12.00:-12.00
I use DOSBox ECE r4475. Is this normal with this game?
EDIT: changed some settings (SETUP.EXE) and found this happens only if I select Sound Blaster Pro. All other profiles including SB, MT32 or General Midi have no issue.
