First post, by HunterZ
- l33t++
First I should mention that I'm using the latest DOSBox CVS, built myself using MinGW32/MSYS. The only modifications I've made are linking in the latest Munt source and tweaking a few Tandy-related things temporarily. I'm also using Windows XP Pro.
I decided last night to try installing the DOS CD-ROM version of X-Wing in DOSBox to see what it sounds like with Munt, and discovered something weird when I did a dir: No matter how I mounted the CD (tried various combos of -t cdrom, -usecd, and -ioctl), I couldn't see anything in the root directory except for subdirectories, and I didn't see a volume label. I was still able to run INSTALL.EXE from the root directory, but then it complained when I tried to install to the hard drive (saying it couldn't read some files).
I copied the entire CD to my hard drive and mounted that directory as a CDROM and was able to see everything and install without problems.
Any idea what the deal is?
