First post, by crash.
Hi,
I'm trying to use a serial joystick device whose driver will not load since it detects there is already a mouse driver in memory.
The device is a Logitech Wingman Warrior joystick, and it is connected to the computer via a USB to serial adapter on COM4. I have configured dosbox to use this serial port.
The message I receive is:
Another mouse driver is present in memory, this mouse driver cannot be loaded. Please remove the existing mouse driver then load this mouse driver.
I tried inserting the following in the dos section of the dosbox config:
int33=false
Is there any option to prevent dosbox from loading it's own mouse driver?
Thanks
Reply 1 of 5, by _Rob
I don't think you can do that in regular DOSBox.
In DOSBox-X you can disable the PS/2 mouse emulation by setting
auxdevice=none
in the [keyboard] section of the config file.
https://dosbox-x.com/wiki/Guide%3AMouse-suppo … OSBox%E2%80%90X
Reply 2 of 5, by crash.
Oh thanks, I will try that. I had run across a different method using a program called MOUSEOFF that I found here, but I'll try the correct method. Thanks!
Re: Mouse problem
download/file.php?id=5488
Cheers
Reply 5 of 5, by crash.
Hi,
I have not been using DOSBox -X, but was using DOSBox. I installed and configured DOSBox-X, then disabled the mouse (auxdevice in the the keyboard section) using the included DOSBox-X configuration tool.
Thanks
