First post, by zymomonas
Hello,
I have a lot of fun using DOSBOX in the last weeks. Most of my old games are working well without any special adjustments. But with some it is more difficult.
A special problem seems tobe ultima7 (part2 serpent isle). Although I have disabled EMS and the status shows "you have >7000 KBytes xms" after typing in "mem" serpent isle does not run and displays a message "serpent isle requires 1024000 bytes of extended memory. You only have 0 available". It's kidding me!
Interestingly, ultima7 (part 1) runs well with these parameters.
My old autoexec.bat that I adjusted for ultima7 included no mem commands at all. I simply did not start emm386.exe. But that's not possible in DOSBOX.
I also know about Exult but I want to get the system running under DOSBOX.
What can I do? 😕
