gmtime() gets you GMT (Greenwich Mean Time, I assume that's what others mean with "Zulu Time"), although these days it's officially called UTC (Coordinated Universal Time). It uses the OSes information about time zones to do that. Actually, it's the other way round: localtime() translates a Unix Timestamp, the number of seconds since 1.1.1970, 00:00 UTC, into local time, while gmtime does no translation.
Here's a little trick: If you know the offset in seconds (according to Kippesoep that would be 15*60*X, where X is that timezone byte), you can set the external variable "timezone" to that value, and localtime() then translates into that timezone. Just make sure you call "tzset();" (exactly that way) once before you change "timezone". These two functions are part of POSIX, so should work everywhere but on MSVC.
I did a little more resarch: MSDN tells me that on MSVC, they are called _tzset and _timezone, so it's just an additional underscore.
And if you don't find a way to fetch timezone information from CD, here's a wild guess:
If this information cannot be obtained, PST8PDT, which signifies the Pacific time zone, is used by default.
Perhaps because of this default, many (all?) old CDs are in the time zone as the one discussed earlier.
