First post, by Starface
Hi everybody!
I really hope that you will be able to help me! I'm desperate!
I would like to know exactly how to make these two games working perfectly with dosbox 0.63.
I can play with crusader no remorse with the configuration i did in d-fend but somethimes the game is slow.
For crusader no regret it's the same probleme but moreover the movies are very very slow and it is impossible to watch them.
If someone can help me and explain me how i had exactly to do to make these games working fine, i 'll be so thankfull!!!
Excuse my english, i come from Belgium.
Reply 7 of 8, by Lochmacher
USE XMS and EMS!!!
TRY SURFACE RENDERER and NO SCALING
CYCLES @ 16000 (sound might be off)
INSTALL W/O MUSIC (if possible)
DISABLE OTHER SOUND-DRIVERS NOT USED (Disney etc)
NO DBL BUFFER (slower with)
USE SMALL VIDEO INSTALL (may not be needed, only if others tried)
USE MAX DOS MEMORY (63k)
GOOD LUCK!! 😀
Reply 8 of 8, by eL_PuSHeR
@Starface:
It's DOSBox, not Oldbox
@Lochmacher:
Avoid writing everything in CAPS, please. It's as you were shouting at us.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
