First post, by eL_PuSHeR
- l33t++
CPU: AMD Sempron 3000
Mainboard: ABIT NF7 2.0
Chipset: nVIDIA nForce2
Memory: 1GB DDR SDRAM
Video: ATi Radeon 9600 AGP
OS: Windows XP SP2
Dosbox vers.: 0.63
Core: Normal & dynamic
Cycles: 10000 - CPU at 40% usage
Eye of the beholder 2: The legend of Darkmoon version 1.1
Description of problem:
EOB2 runs just fine but moving around using the keypad keys (4, 6, 8, 2, 7 and 9) is fine except for the "keypad 9 - PgUP" key which is used for turning around (anti clockwise). You have to press it several times for it to respond. Weird thing, the other keys respond properly. The mouse responds properly too.
Reproducibility: Always. Tested on two different machines.
Running it natively or using VDMSound exhibits same behaviour, so I am beginning to think it must be a bug in the game.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
