First post, by MrOizo
If this should go to the "Dos/Win Applications" forum, then my apologies in advance. However, the problem I'm having is more of an OS-install issue than that to config a particular app. I've just installed Windows for Workgroups and set the display driver to either VGA or SVGA. Both times, I get "Video initialization failed. You need to run setup again".
With the install, I left out all of the networking stuff, however, I did not try to include the settings from the config.win so far as I don't know how this should work in emulation with no config.sys file being present in DOSBox.
Did anyone encounter the same issue? How did you resolve it?
Personal/overall note: DOSBox is a great program. That is not only for games but also for old applications that I used to use back in the days. Great soundcard and video emulation, you really did a good job with this. Thanks so much for the program!
Enjoy your weekend,
Mr. Oizo.
